Found a new on on E-Pay for $22.
Here's a service manual for that:Working on my sons Grasshopper engine that pushed the main seal out and was leaking oil. My question is what would cause enough internal presser to push it out? I checked the seal and there is nothing wrong with it. Could the crankcase breather be plugged up causing this. The engine is a Kohler CH 25. Where is the breather located on this engine?
Ordered the ends from McMasters foe $11.00 Hope they fit.Found a new on on E-Pay for $22.
Your original looked like coarse thread from the pic.Ordered the ends from McMasters foe $11.00 Hope they fit.
Bent a mower blade on the JD 265. Hit the top of a water main valve cover.
Looked at the deck for the 316 and they were nearly new, so swapped the blades out for now.
It was in the yard! I forgot I had lowered the deck some. Brought it back up and went over it this time.Stick to your lawn, keep the mower off the street.
You aren't far off Noel, last October I bought a new battery for my wife's Denali. The old one was still working then so I put it in the '55. We had no clue how old the battery was in her truck so just to be safe with winter hitting we put the new one in her ride. Last weekend I tried starting the '55 and just clicks. Boost started it when I got home from work, and trickle charged several hours. Next morning tried to start it to go to work, clicks again. Enough of that then, time for a new one for that truck too! Starting good again in the morning! The last time I bought a truck battery before these two was 2015 for the 72 GMC so I guess They are lasting fairly well.Doug, I thought you put a battery in the 55 last year. Or was it something else you put in. Is she 12 volt or 6 volt. ?
