today was GT carnage day. I went out to the barn to get everything running that I could (fairly) easily and start mowing for 1st time this year.
I had taken all the batteries out, brought them home and charged/tested them, had 4 good and 3 duds.... during this past week I went to Interstate and swapped the duds for good ones. I put batteries in 4, and all started right up after winter...... 2 of John's (barn/property owner) and 2 of mine....
I did have a bit of an issue w/ my Cub 129.... the fuel filter was clogged solid, someone before it was mine, put one of those marine, see thru, screw apart fuel filters on it and it was plugged solid. So I fired up the (gas) compressor I have out there, wrap around rope start and all, blew out that fuel filter and a couple air filters, and started mowing......
1st up, was my New Holland S14 that has the M12 Kohler on it, took it out and it seemed way down on power, bogged way down like it has never done before... this was the machine my son borrowed the last year and 1/2, this was the 1st time since before then I tried to use it.....
the bog out was easy, the gov link popped out of the carb.... just glad it didn't swing wide open.... popped that back in (needs a new clip which I have plenty of) and ran like it always did after that. BUUUT..... I got into a rough patch where the farmer next door had been with his tractor, "buckboard ride" and the front hanger popped off for the deck, front of deck was riding on the scalp roller.........
OK, pop that back in, swing down the lock tabs (my kid had had the deck off last year and didn't set the lock tabs) Nother easy fix..... BUT then I discovered the big issue with this machine. The frame around the engine was soaked with oil, the scalp roller and front of deck, and it had run forward out the front of frame.... not smoking, out the exhaust or the breather, but went from "full" to "add" in an hour..... I topped it off again and finished that section, then parked it.
Next up was one of John's (he has 2) Cub 1200s..... I mowed with that for a while, that thing always has been a bit rattley ever since I put that engine back in after the rebuild with solid mounts instead of replacing mounts with genuine Cub rubber mounts.... 4-5 years ago.
After mowing with that one a while, it faltered like it was getting low on gas and I was farthest from the Dakota with gas can in back... so I cut the PTO off, made a U turn and put it in 3rd hoping to have to walk as little as possible up the lane to get the gas can....
I made it back to the truck without another cough out of that 1200, and noticed that while it was getting low, it wasn't that close to out of gas.... I set my hand on the air cleaner lid and the whole engine moved.....The cradle is tight, the engine is loose on the cradle.... I dunno if its just loose or if it lost all its bolts.... I'm thinking the 2nd thing. I wasn't wanting to sell that one but no sooner did I get that engine back in and running, John begged and pleaded with me to sell him one of mine so he has a "back up". I didn't want to, but I figure since he has Cubs, I'd let that one go as decks and such would interchange between them..... shortly later he was complaining about an oil leak..... as it turns out, the base plate was cracked, I had to find another about 3 years ago.
I finished what I had wanted to today, on machine #3, John's Cub 1250 hydro.
John is in a "retirement village" for the last couple years, but before then he was "high gear thru shin high grass" type of machine operator. and couldnt understand why he was always burning belts and other issues..... My wife and I did this place all last summer and never burnt out a single belt.... it got mowed more often than in past years too..... My wife and I would re mow when need be, 2nd trip over ground we just mowed, John wouldn't....... since he has been in the "retirement village" there has not had to be near as much re-mowing......
so the engine has to come out of both my New Holland and his "1200 #2".... grrrrr........ I have his "1200 #1" that he has owned I believe since new (in the late 70s) that I have to put a clutch into, here at my house. I knew John from a past job in the 90s and early 2000s and he has let me store some of my "junk" out at his place for years......
