Have a cub 782 with a rebuilt brigs L head twin in it that I wanted to finish up. Needed a new gov spring and gov adjusted then break in that new motor. Key would not make sound from the starter. Pulled the gas tank so I could get at things. Found a loose wire at the ignition switch. Engine turn's over now so the tank goes back on and get it running this morning pulling a cart around some a various speeds. May put the deck in gear and let it cut some grass just to say it has done some work. 16hp L head that is bored 10 over. Donner from a 582 after the KT17 ventilated the block.
