The ongoing process of getting my recently acquired 1969 Ford Falcon Futura wagon continues. After replacing the rear air shock's cracked air lines, I replaced the front shocks, which improved the ride tremendously. Sometime in it's past engine swaps, the windshield washer system was removed. So, I went by a local You Pull It and found a combination radiator overflow/washer fluid reservoir from an early 90's Ford pickup for $16 as opposed to $65+ for a new one (plus $15-$20 for a washer fluid pump). After some cleanup, I have a nice tank and the pump is working nicely. Now I just need to purchase a washer hose/nozzle kit and hook it all up. I will mount the new tank where the current overflow tank is. The connector for the washer pump was tied back in the wiring harness and in good shape. The connector was good and the correct one for the washer pump.
Figured out that this car has a TCI Sizzler C4 transmission and torque converter.... also has a Detroit locker in the rear differential. Nice! This thing is getting better by the day and is fun to drive. Sounds awesome! It's a real sleeper..... nice stuff under the hood, but a wagon! This will look really nice with tinted windows. The air conditioning system has bubbles in the sight glass, so I need to get by our favorite local shop to see if the system will hold a vacuum, then go from there.
