I find cucumber tastes best when I bust them in half and throw them to the chickens.I do love me some pickles though.
Drilled and tapped a broken bolt on the Purple Sears this morning.
The rest of the day was spent replacing all the trim, seals, and brick molding around a garage door for a friend/client. I was in the sun most of the day. Working in an air conditioned lab for the last 24 yrs sure made me soft![]()
Is that tundra up there?Feeding potato chips to my co pilot, looking at last weeks screw up at work and watching neighbour across the swamp while breaking 40 acres of what was standing timberView attachment 16582View attachment 16583View attachment 16584
Yes that’s axle deep...
was mowing the paddock during the week
and it developed a oil leak from the engine , (1970's Rover Rancher 2 ,$100 special ,11 HP briggs 5 sp manual, brought it when i wasn't well) seat and cutter deck is tatty and needs a seat pad ,i use a cushion for the moment , not the correct paint either looks like $2 spray can job but runs well
1st thought it was the lower crank seal but having a better look turns out it was the filler tube had been loose and wore the plastic a bit which let it come up out the seal recess a tad to leak .
i cut a small piece of plastic hose for the moment and removed the bracket on the engine that holds the filler tube in place then sat the hose in between the filler tube and tube bracket and done the little bolt up to hold the filler tube down nice and firm, no more leaks now
Shane
Sad i brought 2 seals so now i'll have 1 spare after i do another engine 11HP,I have 8 of those machines in total some paid for some from curbside 2 from rubbish dumps lol its a shame they are so light in weight though , my day was easy compared to yours though , hate it though when buying stuff and it's not right or bits missing So frustratingThat's a darn good repair on a cheap workhorse, Shane! Wish I could run into cheap and free deals like you do!
I'm hoping that the 4th try on my wife's '06 Yukon hydroboost unit is going to work! It better as this time it cost $270 bucks! I went through 3 "American made" seals where the leak was and all of them leaked worse than the original one. I was out of time to get any more seals from a "Chinese" outfit in time to go to Denver Friday. In this case a China one probably would have been better! I called around again and the local NAPA did find one hydroboost unit in their warehouse so I figured I better grab it. There was more drama as I got the core out of the truck and went to NAPA just before they closed at 5 pm last night. I opened the box and the fitting placement and mounting bracket looked right so home I went. I get home and get things ready to install and there was no master cylinder push rod, spring or retainer that holds them in the new one! Then I find a note in the bottom of the box that says that stuff must be re-used from the old unit. It was too late to go back and get it figured out so right after I got off work this morning it was head for NAPA again to get my needed parts! I took the tools to split the case in the core unit as the retainer is too easy to damage without disassembly. It's no problem installing it in a new unit though that is already assembled. I had to use the tailgate of my '72 GMC for a workbench to split the core to get my parts out in the parking lot, but they were ok with that. Good thing I took a chunk of cardboard with me as they are messy to open. I assembled the core again and gave it back. Had the truck running by noon. Then it was time to clean the shop and maybe get back to a normal life! Lots of power steering fluid spilled on the floor to clean up. Then I loaded 6-55 gallon bags of crushed aluminum cans in the '72 to take to the scrapyard. I hadn't done that for a year and a half! Probably still around 45 cents a pound I suppose, and it should be about 90-100 pounds.
