Did you have the belt on the inside pully, that is the one for lining up with the idler pully.Started out with the string trimmer because the grass was still too wet from a small shower overnight at 11:00 this morning. I mowed for about an hour and threw a PTO belt. I put that back on then did it again a half hour later. I really like the rear fender pan lift on the Simplicity 3415H. I watched the belt for a moment and noticed my idler pulley was sitting too far outside causing the belt to ride on the inside edge. I removed the pulley and spacer then replaced the spacer with three washers bringing the pulley in about a 1/4” allowing the belt to travel dead center. Finished up around 2:30 got a shower, ate, and done nothing the rest of the day.
Here’s a couple of pics RadDid you have the belt on the inside pully, that is the one for lining up with the idler pully.
Glad it wasn’t any worse Marty. I ran over a yellow jacket nest one time. I actually leaped off the tractor. Them things got up my left pant leg and wouldn’t stop. The more I beat on them the worse they got. I had to take my pants off and ran to a cabin we had on the property. We had a pond but it was too far away. My leg from my ankle up to my knees was covered in stings.The moment you realize you just ran over a ground Hornets nest...... was mowing field on our zero turn, had a one land on my hand, thought it was a honey Bee so I stopped mower. Next thing I have 2 or 3 more and I turn to see the ground swarming. With all the safety's, I just stepped off mower and walked away. I'll get those boogers one evening, only got stung 4 times.
4 stings is still too many! Those buggers can sure put the hurtin on ya!The moment you realize you just ran over a ground Hornets nest...... was mowing field on our zero turn, had a one land on my hand, thought it was a honey Bee so I stopped mower. Next thing I have 2 or 3 more and I turn to see the ground swarming. With all the safety's, I just stepped off mower and walked away. I'll get those boogers one evening, only got stung 4 times.
Glad you only got hit 4 times, Marty! They have to be the most worthless insect on earth. All they do is inflict pain and contribute very little to the environment!The moment you realize you just ran over a ground Hornets nest...... was mowing field on our zero turn, had a one land on my hand, thought it was a honey Bee so I stopped mower. Next thing I have 2 or 3 more and I turn to see the ground swarming. With all the safety's, I just stepped off mower and walked away. I'll get those boogers one evening, only got stung 4 times.
You didn't give use pictures so don't know exactly what you have. But I do know that my Sears 18/6 with loader is very unstable and near useless without its dual wheels. I made three rail chains for it to compensate for the poor traction caused by low ground pressure in the back.I thinki if I would have stepped up on the foot pad would have been enough to hold it. I could have reached the lefer then. I had it held and didn't really want to move. Those back wheels are set out as far as they goo too. Would like to get them out another 8-10" further. Weights on the rears also. I think it was the weight of the bar from the mower on the down hill side that caused the situation. Won't happen again though.
